Can this power steering pipe be repaired ? Pics included
6 Jul 2025
Its a power steering pipe from my 2010 Mercedes-Benz e350 3.0 v6.
Its leaking from one of those sections arrowed.. can it be repaired or not ?
Tia
I had a pipe a bit like that, made up of metal and rubber sections, on an ac line in my van. One of the rubber sections had rubbed on an engine mount and worn a hole. It was going to be problematic and expensive to source the new line, so I sent it off to an ac specialist to get a new rubber section crimped in.
Maybe they can do PAS lines too. This was the company -
Any hydraulic hose company should be able to make you a new one, possibly even using your existing connections.
Thanks I'll check that out
Not a clue, Pompey dockyard used to make them for aircraft lift systems but never invoiced me :LOL:
There used to be a similar arrangement through a local car parts shop when I used to work in Filton, Bristol. For a couple of packets of fags or a nominal sum, they could get one offs made at either Rolls Royce or BAC/British Aerospace for certain hard to source parts. Was quite handy because I was driving an old P4 Rover at the time. Had the knock over plates to retain flywheel bolts and a few other things I can't remember made through them. All top quality and aircraft grade materials. One bloke had some seat frames made for his series 1 Landrover.
