- Joined
- 6 Jul 2025
- Messages
- 56
- Reaction score
- 0
- Country
Unlikley.
I wouldn't even spend money or time trying
Just Google 'power steering pipe repair' and add your local county.Its a power steering pipe from my 2010 Mercedes-Benz e350 3.0 v6.
Its leaking from one of those sections arrowed.. can it be repaired or not ?
Tia
Any hydraulic hose company should be able to make you a new one, possibly even using your existing connections.
I had a pipe a bit like that, made up of metal and rubber sections, on an ac line in my van. One of the rubber sections had rubbed on an engine mount and worn a hole. It was going to be problematic and expensive to source the new line, so I sent it off to an ac specialist to get a new rubber section crimped in.
Maybe they can do PAS lines too. This was the company -
Air Con Pipe Repair | Vehicle Air Con Specialists | BonAir
Fix your vehicle's air conditioning system with our specialised air con pipe repair designed for cars and vans. Contact us today for a quote.bonair.co.uk
It's the only way, or a replacement from Mercdes themselves.Thanks I'll check that out
Not a clue, Pompey dockyard used to make them for aircraft lift systems but never invoiced meHow much do u reckon that might cost
Not a clue, Pompey dockyard used to make them for aircraft lift systems but never invoiced me![]()
