- Joined
- 26 Jul 2015
- Messages
- 315
- Reaction score
- 8
- Country
I have currently got wood facia board grooved with a ply soffit in. I did my downstairs garage to learn all the requirements to cap/add soffit trim etc and that went ok, I just screwed the soffit on the lip of existing fascia and threw the capping over to support it.
I'm doing the roof now and the Original windows were replaced a while back and they literally have zero gap available to put the fascia capping over the existing fascia wood board.
Key challenge is I've ordered all the fascia capping board, before you say anything, I tested with a small bit of facia it on another upstairs window but that one for some reason was just about fine to get the fascia on the existing lip.
I don't want to get this existing plywood soffit out, it's laid along the brick line and im seeing this as causing more aggro with the brickwork.
There is a 20MM between existing soffit line and the bottom of fascia, when the new Soffit is on that is 9MM, that leaves 10/11MM.
Fascia is 9mm thick, leaving 2MM.
Has anyone had a similar issue?
1. Cut just enough fascia board off the existing lip all the way along the 10M front/back with a jigsaw?
2. Use router to do the same?
Or is this whole plan doomed OR am I overthinking it.
