- Joined
- 6 Nov 2023
- Messages
- 3,614
- Reaction score
- 1,080
- Country
But there are a lot of factors why they have a lesser chance of catching fire than ICEV’s.That's what I meant about statistics. Like the ones we have for cars, for example, which show that EVs are less likely to catch fire than ICEVs.
And correlation doesn't equal causation. The lower number of EV fires could be influenced by factors like newer technology, fewer EVs on the roador stricter safety regulations and not necessarily that EVs are inherently safer if you think that.
So which is better then more frequent fires that are easiet to put out or fewer fires that are far more dangerous?
Should safety be judged by how often something happens, or by how bad it is when it does?
Would the “other causes be driven by the users mistakes or ignorance?I would ask you to compare the damage caused by lithium battery fires vs the damage caused by other causes.
And if comparing it comes up with lithium batteries causing more severe damage (which they probably do) then are traditional firefighting methods as effective against lithium battery fires as they are with other common fire types?
