- Joined
- 3 Sep 2025
- Messages
- 23
- Reaction score
- 0
- Country
I rent a small 9 square meters office on a 2nd floor of a recently fresh building. The building has a central VAC system with good airflow, but it's turned off overnight. I don't expect humidity and temperature swings to be considerable anyway especially on the 2nd floor.
Now, the office's floor is covered with a very thin berber carpet, I guess it's 4mm for a hard rubber base and 3 mm of rigid pile. When walking on it feels almost like a vinyl sheet, just enough soft to isolate you from what I think is concrete (typically used in offices).
I can't have the carpet flooring as it will not pass licensing checks (the business does some health/beauty treatments), so I was choosing between SPC/LVP or laminate. It's worth saying that some "furniture" will be quite heavy, like a 85 kg treatment chair (+ client's own weight), but it's just one such item, the rest are nothing to worry about. Since I'm no expert in flooring I first listened to what all experts in the world suggest to do - remove the carpet, prepare the subfloor and install using a DPM/underlay. All because the heavy load and SPC requires an "ideal" floor. But then I realised how much effort it would take - first to remove, then when leaving the office - installing a new carpet to restore the initial look! So I did some more in-depth research about how I can keep the carpet. And it looks promising.
Current flooring
Very rigid berber (7-8 mm thick) on concrete, 9 sq meters (3 x 3 ish)
Solution
Large (2440 x 1220 x 11) OSB sheets goes on top of the carpet (3 sheets, cutting will be needed), to compensate for any instability of the carpet. Then some sound isolation and 8mm thick laminate on top. SPC/LVT was ruled out as their locking system is not enough sturdy.
Questions
1. Can I skip OSB/other kind of board completely in favour of a thicker (12mm) laminate laid directly on the carpet? Or use a thinner OSB?
2. Laminate on OSB needs some insulation. Can I go for the thinnest and rigid available?
3. OSB is class 3 so itself needs no DPM. However it still can expand and contract so the advice is to leave 2-3mm gap between the sheets. But is DPM needed for the laminate? Glued in carpet, then OSB and noise isolation - surely a DPM is too much?
4. The corridor on the right needs to be covered with OSB and laminate. I guess it's ok to have it as that area will host some static furniture unlike the left and top part of the room where most of the activity will take place.
5. The floating inset panel idea under the door - is it good? Want to use some removable double-sided carpet tape to keep it in place. Thresholds and reducers on the perimeter secured against OSB/wall/door frame (not the inset panel)
6. Any tests I should run on the carpet to make sure it's suitable for the above?
Current flooring
Solution
Questions
