- Joined
- 17 Aug 2010
- Messages
- 4,654
- Reaction score
- 1,814
- Country
seems a little worse than mine but certainly same ball parkI haven't tried any calculations recently but I've always worked with 13ft of 15mm and 6ft of 22mm Cu pipe to a pint. I have roughly 12ft of 15mm (50:50 buried in wall: free air)-1 pint +10 ft of 22mm (insulated) and 8 ft of 22mm triwall PVC (insulated and enclosed in glass fibre insulation) - <3 pints. Total <4 pints or let's say >2L.
I'll say filling a 2,5L pan the water is running 'quite warm' but it requires about another 2L to run too hot to touch.
it is certainly not just heating the copper that accounts for the loss
I think we are all agreed copper heats up instantly ( or at least Pretty Dam Fast)
4.6m copper pipe would weigh 1.2kg and hold 0.67 litres
0.67 litres of water at 55° would only loose 6° of temperature in heating up 1.2kg of copper at 15° (water & pipe would be 49°)
and yet it takes 3 litres to get up to heat - in an ideal world it should take less than half of that - is Arthur c Clarke about ?
