maybe. But there are tariffs where the whole house changes to cheap rate, not just the car.
Not if you have all the storage heaters on!(and ur, The dishwasher of course, trying to bring it slightly back to the topic)
Anyway, who said anything about night time.
It really does not matter what battery and inverter you have, whether built into a car, or part of a solar array, if you allow the supplier to control when you charge and discharge the battery, they will give you a better rate.Probably because the energy demand for EV's can be dynamically adjusted by the suppliers, whereas E7 demand simply cannot.
has an off-peak, standard, and peak. The off-peak only 3 hours, and the peak 4 pm to 7 pm may work out OK in summer, but winter I may well run out of battery by 7 pm and by 4 pm I am being careful what I am using, so one would need a massive battery and be active ensuring it is charged before 4 pm, so one can export at the 30.68p/kWh, for me far too much hassle.
seems good at a quick glance, but the night rate is still much higher to the Go rate for EV users. And I do not need 7 hours off-peak, it takes around 1.5 hours to recharge my batteries, but the tumble drier runs for nearly 2.5 hours, and depending on when you set it, you have ½ hour or 1 hour increments of delay. Setting it to line up with a 3-hour off-peak slot can't really be done. So either to start or finish it will be using battery.
but the battery state of charge (SOC) is enough to likely reach 00:30 tomorrow when off-peaks starts without running out, as charged up overnight. But Friday exported 17.8 kWh, so the EV tariff works well, 8.5p off-peak 00:30 to 05:30 and 30.17p rest of the time, which I rarely need to draw on, and export rate at 15p/kWh so if I import more than I need, I am not loosing.If one has an "EV tariff", can the supplier distinguish between electricity being used for EV charging and that used for anything else? I would have thought not, but may be wrong. It presumably would only be possible if the EV charger could 'talk' to the supplier, maybe by somehow using a different register in a 'Smart' meter?Would an EV tariff allow SH's?
OK. Thanks. How is that communication achieved? If it relies on the GSM network, then they would probably have the same (very small) amount of luck in my house as a 'Smart'meter would haveChargepoints are required to have the ability to send and receive information to/from the supplier and the ability to respond to signals to vary the rate or time at which charging happens.
Fair enough, but the point made in the title of your link ("3.9 of the document") is then followed by ...
... which doesn't necessarily make us much the wiser3.10 A charge point must be configured such that when it loses communications network connectivity it is still able to charge an EV, to ensure owners are still able to charge their vehicles.
3.11 The Regulations do not specify how charge points should operate in the event of a loss of connection beyond them just being able to charge an EV.
Yes, default settings for when it allowed charging to happen, but if there were no comms, so that the supplier didn't know how much EV charging had been done, and when, I suspect that the user would not get the reduced 'EV charging rate' for their charging, would they?Presumably they'd have to operate under the default settings. But with no comms, I wonder how it knows what the time is?
Technically yes, in practice only if installed before 2023, the solar installer could pre-2023 install a meter for export which would be assigned an MPAN number, but early 2023 this was stopped, and the supplier on new installations can only use the smart meter for billing. The supplier can be given control of devices, be it the car charger or the solar inverter, but billing now has to be with the smart meter.So a customer could be on a single tariff, and have a dumb, single-tariff meter, and still pay special off-peak EV rates. Or he could be on a traditional 2-tariff one, and pay a different off-peak EV rate from the general off-peak rate.
