Here is mine for the 45 degree bracket. I have 2 resin fixed threaded studs at the front of the house at bedroom window height so I can lean out
Slip the bracket on and secure with butterfly nuts. Its 20mm overflow pipe and the swivel is from a locking nut I cut the centre a bit bigger. The black bit is glued in place to stop the swivel sliding all the way down - the bottom is the same but I have added an aluminium section to strengthen the plastic pipe.
I can not put my hands on my bracket but its a little bit like this but 45 degree it slots onto my 2 studs and the pole slots on and mine is tightend with just one butterfly nut by hand whereas this one is 2 nuts
