Motor below, has a recessed below the deck, D shaped drive shaft. A plastic part fits that, with the usual three arms, to locate onto the underside of the glass dish, with the dish stabilised, by a ring, with three little wheels, but the plastic, three-armed part, is set too low, to properly locate with the dish, to drive it round reliably.
all fully turned now and the mortices and tenons all cut
first one glued in - tricky bit next getting the other two to the same height so the table sits level - some times this is easy and quick, other times its a nightmare
tip for when doing tenons - cut them so that they are just a little too tight, then nip the tenons in a vice until they slide in - the dampness in the pva will get them to spring / swell back out (like a biscuit does in a biscuit join)
Jimmy Jones' catchphrase. He lives near me. Reg number K1NEL. Ford eco sport nowdays but used to be on his Rolls' and Range Rovers when his popularity was high - appearing at the circus tavern every other night anyway! From the Bernard Manning school of 'comedy'.Kinnell
