Yes, you've often said that. I've never had one of these new-fangled freezers, so don't have personal experience, but I thought the idea was that most of the 'frost', hence defrosting, happened outside of the freezer cavity, such that the temp inside the cavity probably did not rise much during the 'defrost cycle'. Is that not the case?
That is the case. The frost, and ice, forms on the colder parts, which are at the very rear of the internals, which are segregated by a plastic wall, with vents to the main food storage compartment. The fan circulates the cold, via the vents, to the main compartment. With the fan off, and the fridge in defrost mode, defrosting just the small rear compartment, then it should make little difference to the temperature of the contents of the main compartment, at the front.
