Samsung WW90J5456MWEU
The door seal was getting torn up and bits of the seal appearing both in the seal lip and in the filter. So I changed the seal last week and it seemed fine until today having been used about 6 or 7 times since.
I was in the house while the machine was on and while it was spinning and first heard a bang from the machine then it was very noisy like it had a very uneven load (it didn't) and when it finished and I opened the door there was a smell of burning rubber and lots of grey gunge which appear to be worn off the seal.
It seems like the spinning drum has been rubbing against the seal and eating it away.
The bearings don't sound bad and the drum rotates smoothly and quietly by hand? The drum is closer to the seal at the bottom than at the top but not excessively so. When rocking the drum assembly by hand it seems a bit looser than I would expect and can easily be pulled and pushed forwards and back to bang the front and rear of the machine case - I'm not sure if this is normal?
There must be something else wrong for it to completely destroy the original seal and to start to damage the second one.
What do you think is causing this - thanks in advance for your advice and suggestions.
