Electrolux EOB53000W door seal adhesive
Can you please confirm it's the first part at the top of the page on Ebay that you are referring ? Thanks
No, any of those, matching your model number, should be a suitable fit. I'm not recommending any particular one, just pointing out how easy the seal is to source.
Ok, it's just that mine has rounded corners and some are 90 degree. I have emailed the seller (the top of the list) but had no response. I just want to make sure thanks.
Over 8 months later and still not fixed this?
The supplied part number (post #19) gasket clearly has embedded metal clips near the 4 corners in
this web picture https://www.partscentre.co.uk/electrolux-oven-door-gasket-3871945105.html
My wife made a temporary fix with wire that lasted that time but now a piece has completely broken off hence having to replace. The link you kindly provided is showing a higher price (and then another £4 postage)
Would this be ok ?
