I'm looking to drain down my hot water (tap) pipe before replacing 15mm with 22mm hot water pipe. I have added a 15mm drain valve to my cold water pipe and plan to do the same to my hot water pipe. This is to stop, after I turn the boiler off and cut the hot water (tap) pipe from leaking torrents of water. My boiler has a 15mm copper hot water tail. Can I add a 15mm drain valve (compression copper fitting) 2m or more from the boiler? I DON'T want to isolate an existing valve (if it exists) on the boiler itself.
