Looking for some advice please
I have gas central heating with a hot water cylinder and two tanks in the loft (cold water for cylinder and bathroom, another for rad expansion). I have an old boiler (maybe 20 years old) and a potterton EP2000 programmer - I have one thermostat for the CH by the programmer, and another thermostat on the cylinder for the hot water temp.
My question is whether this is a gravity fed, or gravity pumped system.
If I look at the pipework, I can see four pipes, CH out, CH return, HW out, HW return. The HW and CH out each have a red pump (where I can control the flow rate). I do not see any form of mechanical valve. When either the CH or HW program trigger, both pumps fire and start circulating water. When the hot water comes on the rads heat up, when the rads heat up the hot water also goes to the cylinder.
I am looking to replace the thermostat with a new smart one, and when I started looking at the wiring, I noticed that there is no HW off wire connected, but I do have two wires connected into CH on, so wonder if someone has wired this wrong, or whether I'm just on a really strange wiring config?
Anyway, this led me down the rabbit hole of, is this really a pumped system? As this influences the type of smart thermostat, and the way I have to configure it
Let me know if you need any photos or other info
Thanks in advance
EDIT: so it appears I am mistaken with my comment about 2 flow and returns. It’s only 1 flow and 1 return, I can see the flow split into the CH and HW circuit, and they join back up on the return - but I cannot see a valve anywhere.
A
Thanks in advance
A
