Pipe and elbow wanted for kitchen sink drainage
7 Sep 2025
Compression fittings on traps work with both solvent and push fit pipe. The rest of your system piping should be the same kind as the pipe you're trying to fit onto (as Wayners points out, push fit and solvent weld pipes are different diameters and aren't directly compatible without specific couplers to go from one to the other)
Any pipe,push fit or solvent will fit that trap but not that elbow.Swap the elbow for a compression one.
are you saying i need to add glue around the pipe before i compress it into the trap
No, on a compression fitting like a trap you jput the pipe into the fitting without glue. When you wind the screw to push a shaped rubber washer into the gap around the perimeter of the pipe it forms the seal.
Remove the screw collar, the plastic slip ring and the rubber washer, and fit them to the pipe first, in that order, then put the pipe into the fitting and slide the items up to the joint 1 by 1 to see how it works/check all is well aligned, then tighten it up
40mm 42mm 43mm Tee Branch Compression Multifit 1 1/2 Bath Waste ...
I got a reducer for it, but it wont thread with the o ring in place
Also the sizes are all wrong, says 40mm compresion, but the pipe it fits is 44mm OD
40mm is just marketing-speak. Solvent weld 40mm has an OD of 43, push fit 40mm has an OD of 41. Compression 40mm is loose enough to accept either, because it's squashing the wedge cross-section rubber washer into the gap that creates the seal
40mm is just to distinguish it from the other sizes of waste, eg 32mm and 50mm, which also have push fit, solvent and compression variants, none of which are exactly 32mm or 50mm
in my limited experance there are 2 micky marketed 40mm's. one big and one small, and they do not cross match over different fitting
That's the difference between pipe and tube. Pipe denotes the nominal internal size of the pipe but tube refers to the OD.
This is why 3/4" iron pipe has a larger bore than 22mm copper tube.
Also as already said there are different plastic waste pipe types which aren't compatible so they are made a slightly different size to stop people mixing them up.
