Well, for what it's worth, I'm not particularly 'happy'!OK I'll start again, the box needs to be accessible not easily accessible.... Everyone happy
Been sensible!What have I done now
Hardly.Been sensible!
Using common sense is sensibleHardly.
particularly if it comes up with the correct resultUsing common sense is sensible
Using "Common Sense" is uncommon to some folk though.Using common sense is sensible
True.Using "Common Sense" is uncommon to some folk though.
Indeed - and it often comes down to matters of 'putting things into perspective' (or not). There's at least one person here who appears to sincerely believe that it is appropriate to 'be concerned' about incredibly small 'risks' (whether in an electrical installation or anything else).We all might stretch points a little bit if we think it entirely reasonable in all/almost all circumstances. ... But some might stretch same far too much just to "prove their point" and justify their existence.
LOLIt always amuses me when I hear smokers, heavy drinkers or those who spend their spare time climbing mountains expressing concern about some unbelievably small 'risk'![]()
This 'keeping things in perspective' issue is often exacerbated when people talk about 'percentage changes' (or 'doubling'/'halving' etc.) of incredibly small risks.
Decades ago, I saw a dramatic and rather sad demonstration of that ...A good saying I`ve seen on here is "Just Because you are Paranoid does not mean they are not out to get you"
As you say, "obviously" - but the point is that (in the absence of definitions) opinions will vary as to what would be regarded as accessible.Obviously there are differing degrees of accessible.
... which doesn't sound unreasonable, but you would need to decide what counted as "making good". It's straightforward enough if one has had to do 'destructive' things to gain access but what, for example would you say about lifting (and then replacing) floor coverings and then undoing (and then replacing) screws in an access panel - would you count that as 'making good'?I think most spark's definition of accessible is that which can be done without the need for making good.
