- Joined
- 18 Aug 2025
- Messages
- 158
- Reaction score
- 3
- Country
Hi guys can anyone answer a question im intrigued by so on a house hold ring main on 2.5mm twin and earth protected by 32amp breaker you can spur off any part of the ring with only 1x double socket i presume this is because if you added more double sockets then just 1 you could theoretically overload the spur cable which say was 2.5mm would be rated at say 27amp max is it ?
so you could overload it by 6 amps before the breaker blew
however i believe its permitted that you can add a 13amp spur unit from the spurred socket and then run as many sockets as you want from that being protected by the 13amp unit
the bit i dont understand though if say you was maxing out the spurred double sockets with 2x 13amp on each point so pulling 26amp you would be almost at the max of spur cable
but then you could pull a further 6amp with the fused spur before the 32amp breaker went and you would be overloading the orginal 2.5mm spur cable would you not ?
