YepTN-S, surely?
YepTN-S, surely?
Didn't we reckon that the installation from Pete's description and pictures probably is from 70/80's so I was obviously referring to that time.I don't think there was anything else (other than TT) until the late 70s, was there?
I bet it's effectively not though, and its TN-CS.
You seem to have misunderstood me. I was saying that I thought that for at least most of the 70s, TN-S would have been the only DNO-supplied earth (and presumably had been for decades prior to the 70s), since I thought that TN-C-S (dependent upon 'PME') did not appear until the late 70s, at the earliest.However, to answer your question, I'm sure TN-S earthing was becoming increasingly common after the 60's?
See above. What you are suggesting is almost the opposite of what I was saying, namely that in 1966 TN-S was almost certainly the only type of DNO-supplied earth.... So in 1966, and according to you, without TN-S and only TT earthing or even barely anything ...
Yes!I don't think there was anything else (other than TT) until the late 70s, was there?
Interesting. As I said, I didn't think it became routine practice until the late 1970s (although I understand that there were some 'local experiments' of TN-C-S in the 1930s).Yes! TN-C-S was common in the 60s. My previous house and the rest of the estate was built in 1968 and they were all supplied thus.
As I have said, solid green went out on 31 December 1977.So do we reckon my house was rewired sometime in the 70's? Its as the picture with solid green earth sleeve, and the original consumer unit was a 3036 wylex rewireable type.
It was phrased badly, John.You seem to have misunderstood me. I was saying that I thought that for at least most of the 70s, TN-S would have been the only DNO-supplied earth (and presumably had been for decades prior to the 70s),
Red Rocker Down for OFF fooled a few folks LOLAs for the
Wylex introduced the Standard range fusebox with a brown front and fuse cover and a brown wooden back and optional (I think phenolic) backplate in 1956.
With thanks to Flameport for the images.
In the late 1970s, they introduced an ivory version with an ivory painted wooden back and an ivory front and fuse cover.
A few years later, they moved on to an all plastic design in ivory, then a few years more to this.
Fair enough. Needless to say, I thought (and still do) that I was fairly clear.It was phrased badly, John.
I had visits from the leccy board to do checks before they would connect me up and they would check the bonding and such-like.The incoming mains supply had a wire sweated onto the sheath and nowadays you`d look at it and think it not much bigger than fusewire by comparison (it was probably a mixture of either 2.5 or 4.0 mm at best in todays currency.
When I became a practising Electrician it did amuse me that everytime a house was rewired the DNO (Electric Board) would come to make the connection and do a few simple tests, Ins res, Ze, Zs and have a look round to visualise the points and might open the odd one or two up just to visual check the wiring and see that bonding of 6.0mm or 4.0 was in place . That was it. Whenever I asked them about the short E from the incoming cable to the customer earth terminal being less than the bonding they never baulked, it was nearly all like that.
They seemed to take the view that equalising gas, water together was more important than the equalising of that lead sheeve of the mains cable and would usually refuse to touch it unless it was literally hanging off or snapped.
Yes, regs-wise it did. However, as I mentioned, I saw solid green sleeving being used much later than that, I suspect because those doing it had 'vans full of the stuff' and didn't want to throw it away!... As I have said, solid green went out on 31 December 1977.
