- Joined
- 25 Apr 2023
- Messages
- 9,196
- Reaction score
- 6,336
- Country
It used to be, with the newer fittings it doesn't matter.isnt it good practice to wire the screw bulb holder so that live is at the bottom center ?
My initial interpretation:Done by the same person who just twisted the earth wires together. Assume everything is wrong.
Might be wise to inspect the whole property looking especially for missing earths. Get a cheapo socket tester.
Edit: I see there is no bit of tape saying “live” in the latest photo??
The 'Blue' sticker is one I stuck on myself after taking to existing rose off. I put it there to remind me which connector the neutral had been connected to!
Convert the fitting to Class I by connecting an earth wire(s) to the metal part(s).
While I am sorry to write it,If they're the wrong way around, they've been like that since before I moved in. I live here a few years... Yikes
I think I'll call an electrician to have a look at it
Not attempt it?While I am sorry to write it,
if you do not know that which you are attempting to do,
perhaps you should.
What newer fittings prevent a finger touching the thread of an ES bub as it's being screwed in or out?
None actually does that but - they do not use the lamp-holder threads as one of the contacts.What newer fittings prevent a finger touching the thread of an ES bub as it's being screwed in or out?
They don't? Really?None actually does that but - they do not use the lamp-holder threads as one of the contacts.
Exactly. They have a small tab on the bottom that touches the thread of a fully inserted lamp. The thread on the lamp holder is plastic or ceramic. Ceramic sockets can have metal threads but they‘re isolated from the supply too.I think he might actually mean they dont use the thread on the lamp holder but they do use the thread on the lamp itself, probably anyway.
