Hi would I be able to put a single socket and piggyback off the switch on the wall?
Just need a single for a WiFi extender
Possibly, what is the purpose of the switch on the wall?
That looks like SFCU
www.diynot.com
Looks familiar, is this the shed fed by a 16A MCB?Hi would I be able to put a single socket and piggyback off the switch on the wall?
Just need a single for a WiFi extender View attachment 399136
Hmmm note to self: Read everything before replyingLooks familiar, is this the shed fed by a 16A MCB?
Yes I did but ended up getting an extension lead instead.I think I can recall @bettz1 proposing to do something similar with the same FCU…
Ah - some context:
Adding a single socket in garage
How easy would it be to add a single socket for our treadmill? I think the previous home owner has added a double socket, so I'm not sure, would it be possible to run a cable And attach a single socket?www.diynot.com
I think it has lol it's got a fuse switch in the fuse box.As long as the circuit has RCD protection then yes, if it doesn't you could get an RCD socket or even change the FCU to an RCD type to protect whatever's on the circuit.
I don't like seeing the gardening tools so close to the unprotected cabling, could easily get damaged if not careful.
The switch is for the lightsPossibly, what is the purpose of the switch on the wall?
