Hi all, got a quick question regarding pipe size and flow rate.
From where my new 28mm mains comes in blue plastic pipe and then gets reduced to 15mm at the internal stop cock and is all 15mm onwards inside, if i replaced this with a 28mm to 22mm internal stop cock and then run 22mm pipe to a 22mm to 15mm T junction where the water splits for cold supply upstairs and combi boiler supply, would this improve flow rate over the all existing 15mm? Especially when using cold and hot upstairs at the same time?
Regards: Elliott.
Regards: Elliott.
