A fully charged car battery is around 12.64 V, 12.18 V = 60% charged, 12V is about 40% charged and 11.6V is basically flat.Don’t understand as it’s a 12v
What actual model is it ?I think I agree with that conclusion but getting the original part is impossible hence why only copies available it rediculous with a 8 year old car and still selling them to this day
Dacia Sandero Stepway 2017What actual model is it ?
My only conclusion is the motor but it was replaced with a non original part and was working for couple weeks but fuse didn’t blow originally ( old motor) but now with new part fuse does blow .
First motor was faulty don’t know why but no fuse blowing at all .It's not clear, or you didn't make it clear....
Did you replace the original motor, because it was blowing the fuse, or for some other reason?
Do you still have the original, and could check/compare resistances to the replacement?
Yeah good idea don’t know why I didn’t think of that , but considering one was blowing fuses and other with unknown fault might get different and unreliable resultscheck/compare resistances to the replacement?
Based on Renault models.Dacia Sandero Stepway 2017
Yes used oem part number still unable to find a retailer for original partHave you put the oe part number into Google ?
Want to share the oe number ?Yes used oem part number still unable to find a retailer for original part
yeah that’s ridiculous tbh thanks for looking thoughI'm told it's available to order but around £700 so stupidly expensive.
I'd go for an aftermarket 1 with 12 month warranty
Ye
Ordered a motor now will keep the old one and repair if I canPull the old one apart, and investigate why it failed - it might be an obvious, repairable fault.
