Can you not buy pelmets? No need to cut the end panels then and, it will look nice...
Tricky colours on mine but I certainly would if I'd gone with white.My suggestion of the plastic sheets cut to size is £50-£70 although mine were white they come in different colours so you may find the blue or more likely graphite, failing that - black ? .
They include but may have been overlooked, they will send some if you request foc.Do you have to request it? I didn't have any in the box.
I didn't because I prefer the look without them. In hindsight... (first kitchen install, will make mistakes).Can you not buy pelmets? No need to cut the end panels then and, it will look nice...
Fit a door, with the cut side to the wall if you can't get one bob onI don't mind cutting the bottom ones, the worktop overhang hides the cut. For the wall cabinets I do feel diy-kitchens have cheaped out not manufacturing to size. Looking at the cabinets (dark blue + graphite) I'm considering not bothering with end panels. It's a bit annoying as it's £200 worth.
Unfortunately that would look pants aswell as the doors are shorter than the units.Fit a door, with the cut side to the wall if you can't get one bob on
I use a Plunge Saw, you may not have one, do you own a circular saw? I use a 48 toothed blade. I also cut face down onto and through a sacrificial sheet of mdf, it stops chipping of painted or gloss surfaces.Even with a sharp mitre blade it's likely the mdf will chip etc and be seen at the top.
Not significantly, and you can't really argue that "putting doors on kitchen units looks bad" because most kitchen units have doors..Unfortunately that would look pants aswell as the doors are shorter than the units.
I think the price gives it away, real SS Handles of a similar ilk are around £15, besides there will be small print somewhere as a get out clause for them.They are pushing back against selling me these "stainless steel" handles - which contain no stainless steel. They seem to think it's perfectly acceptable to sell an apple as an orange. Chargeback is in the air...
I'm not the only one that don't like pelmets though I may well be in the minority. I don't like under cabinet illumination either, looks cheap imo. It's not going to be hard for them to do two different heights and avoid the mess. Regardless, I have one cupboard that's reduced height anyway due to RSJ above it, so I have no option but to cut the ends, pelmets or not. I have a circular with track and the blade is sharp but it's never going to be perfect on painted surface. Given this they should at least supply the relevant touch up paint with what in my case is a £2,600 order. If you've ordered the wrong colour then it's unavailable.
Yeah, by law. In that list they actually do have others with 'Stainless Steel effect' in the title. No leg to stand on. They've caved and will refund the postage but it shouldn't have taken a back and forth.I understand why you are annoyed, but if I go to https://www.diy-kitchens.com/handles/bar-handles the description does say SS effect. That said, perhaps it should be in the product title.
Tried that before I ordered, they don't use RAL codes it's something they make/mix/manufacture on site. They will sell 1Ltr of the stuff they make for about £50 but you have to push - and pick it up (they're not remotely close for me so that was a no go).At a minimum they should be able to tell you what the RAL colour code is and the sheen level.
