Thoughts/advice about welding
28 Jan 2011
Buckinghamshire
Hi folks. I’d been grateful for some thoughts/advice.
I’ve always done a lot of DIY, in a whole range of disciplines and, over the years/decades, have accumulated an equally wide range of portable and ‘workshop’ power tools.
The one thing I’ve never got into is welding, which is something that I would occasionally find very useful. Although I have lots of experience of soldering and brazing, my only attempts at welding was at school, best part of 60 years ago, and related to oxy-acetylene welding.
I’m wondering whether, in my senior years, this is a ‘deficiency’ which would be worth addressing. If/when I had acquired kit and (hopefully!) some degree of ‘competence’ in using it, I would only need to use it very occasionally, and only for small/’light’ projects.
What do folks think? Am I foolish to be considering trying to acquire this skill in my ‘old age’?
I presume (but remain open to correction!) that we would probably be talking about MIG welding and, although the “IG” stands for ‘inert gas’, I gather that it can also be done ‘gasless’ – with a flux-cored welding rod, rather than gas, providing the 'shielding'? Although I realise it would mean limited power, it would be convenient to have a machine that could be plugged into a 13A socket – since, although I have a few16A sockets (and could even create a 3-phase supply if I had to), they are not in the most convenient of places. Any advice/suggestions?
As you will understand, I currently know very little about welding (or welders), but, even at my age I’m a pretty ‘quick learner’ :-) I’ve recently come across things like this (mainly on Amazon) – they look pretty Mickey Mouse (and/or ‘too good to be true’), and presumably are pretty low-powered, but, needless to say, the marketing blurb and ‘reviews’ make them sound like the best thing since sliced bread! Taken at face value, what I read suggests that they might be adequate for the sort of small/light jobs I might contemplate, but am I right in assuming that I should ‘ignore’ them?
Any thoughts/suggestions/insights/advice would be very welcome!
I've done and taught most types of welding (ex pipeline welder)
It really depends on what you intend doing.
Stick together a few bits of mild steel mig would do it, though Stick welding (M M A) is still worth considering.
Add aluminium or stainless tig would be way to go you can also braze with a tig set .
I've currently got oxy- acetylene as I still do some lead welding and a second hand Lincoln stick/tig set.
I have zero experience of welding.
The following review seems to be the most honest I could find.
For years I had an old style air cooled 140A stick welder. It did a job but it was heavy and the arc wasn't terribly consistent. I picked up a set of industrial welding leads at a boot fair for £2 and that made it much handier.
About 10 years ago I had a lot of stuff to do and treated myself to an inverter welder: night and day completely stable arc and the set ony weighs a couple of kg so perfectly fesible to weld up a ladder if you've a mind to do so.
I also have a MIG which I rarely use as to be honest I've never really set myself to use it to get a proper feel for and therefore confidence in it. Mine is gas either small dispposable bottle or it came with a regulator so you could get a larger refillable cylinder. I don't think it will take fluxed wire though many do both.
In theory the MIG is more versatile as it will deal with thin metal rather easier but outdoors wind can take the shielding gas away and lead to bad welds. Stick welding is generally taken as being more suited to outdoor work or if you're trying to weld less than perfectly clean stuff.
The gizmos you show are likely just that: there's a guy on u tube who regularly debunks these kind of wonder tools, I can't recall his name but I'm sure a bit of searching would find him. Laser welding is very much a real thing but costs are a couple of orders of magnitude higher than the toys Amazon and the like offer
EDIT
I watched Opps vid while typing, these are not the laser things I assumed they were and do seem to work after a fashion, but you'll note that the reviewer isn't impressed.
The old adage that you're never too old to learn springs to mind, so go for it
I learned/more less taught myself with little help, whilst working in Italy, using a stick welder Then years later, I got a yen, to have a go at home. I needed shelves, in my new garage, and spotted an ad for some lengths of angle iron, and a stick welder, bought it, and built the heavy-duty shelves. They remain in good use, today. I've made good use of that welder since, though it is limited to thick materials, so I bought a MIG welder. I was never as confident with the MIG, as the stick welder.
To the OP
Welding is a skill that needs practise.
You are likely to find yourself taking ages to get everything set up right and little time actually being productive.
I wouldn't bother, unless you have a large, long term project, to do
I restored a couple of classic cars using a MIG welder bought from machine mart. Not tge cheapest but certainly not high end either. I had welded before and did a few practice runs before committing to car repairs. I tried on a couple of secondhand car panels and some flat plate. Cars turned out well even if I do say so myself and I recouped most of my cash when I sold the welder a few years later.
Give it a go you have nothing to lose and the sense of achievement will be awesome. Even if it doesn't work out at least you will have had a go and can tick that box.
It's very much, a skill and facility, you find a use for, once you have them. Some things, can only be done, by welding.
I don't think it's ever too late to learn new skills!
As the others have said, it depends on what you want to do which will determine the gear to buy.
For light stuff, brazing may be the way. These days there's no need to be drawn into BOC for bottled gas.....motor factors can supply non rental bottles of oxygen, acetylene and argon /CO2 mix. I have an ex BOC 'Portapak' which is very good, others are available.
With brass spelter and Sifbronze flux you can't go wrong.
Then you'll need to consider MIG.......gas type preferred but fluxed wires are available if you perform where there's some breeze!
This is great for larger section metals, say 1/8" or larger. You'll quickly get the hang of it but you'll need a few lengths of scrap steel for practice.
I'd avoid stick welders unless you intend to construct pylons!
If you intend to do car restoration then TIG is the way to go.
For electric gear an auto darkening helmet is vital. With oxy then goggles are fine.
Don't consider (yet) welding aluminium....that's another ball game entirely.
Do let's know if you decide to bash on......many more tips are available!
John :)
Might be a bit far for you, but if you want to learn welding there's:
Which is in Hinckley. The guy that runs it, Bob, features in Mat Armstrong car repair videos on YouTube, and seems a nice bloke and excellent welder.
Thanks. It actually seemed to work a lot better than I had suspected/feared. Although the reviewer said that he would not recommend it, it seems that was mainly because one has to hold the whole relatively heavy 'tool' - which I imagine does not help when trying to achieve a 'steady hand'!
I don't think it's ever too late to learn new skills! ... Do let's know if you decide to bash on......many more tips are available!John :)
Many thanks to you all. As I suspected, a lot to think about and ask questions about (which I'll try soon, but please be patient, because I have limited time at the moment). In the meantime ....
All of the above comments reflect my own attitude to life - my interest in this is primarily as an 'intellectual (and practical) challenge', rather than the result of any 'pressing need'. I've managed for many decades without welding, so I'm sure that I could see the rest of my time out without it - but it's a 'challenge' and, as said above, a potential source of satisfaction (as well as usefulness) if I could develop a usable degree of skill!
Nearly all of the skills I've acquired and developed over the years have been essentially self-taught. Even in terms of my professional academic educations (more than one of them!), I did not find 'being taught' very useful/efficient - so I always tended to largely ignore lectures, and then go away and read, play, and practice on my own (today, 'watching videos' would undoubtedly get added to that list!). I therefore am quite hopeful that I would be able to achieve something given some welding kit, even if it took a fair bit of time and a bitof heartache/frustration!
In contrast ....
Welding is a skill that needs practise. ... You are likely to find yourself taking ages to get everything set up right and little time actually being productive. ... I wouldn't bother, unless you have a large, long term project, to do
... whilst I respect that as well-intentioned, and pragmatically probably fairly sensible, advice, it is the antithesis of my personal approach to 'challenges' and, indeed, to life itself :-)
If I might add a couple more thoughts to my first reply: I learned stick welding purely by watching. When I tried it I had the benefit of the current being set to the rod size (all you can really alter) which is a big chunk of the battle, I was using part used rods which are much easier to control being shorter and easier to strike the arc and I was setting my little plates a lay a fillet in a horizontal v. This is the easiest weld to master so you can concentrate on keeping the arc length constant and moving along the weld at a steady speed as the vee shape guides you for line. The small plates also made it easier to break the circuit when the rod stuck to one!
I picked up an auto darkening helmet from Lidl several years ago and that's a massive help.
There are many specialised welding applications (on pipelines for instance) which are highly skilled but simple stuff is actually dead easy for anyone with any kind of diy ability and a bit of time to practice a bit.
OK, so the start to my questions.
There’s clearly a lot I need to learn, and probably the first thing is probably to find out whether my ‘understanding’ of the various types of welding is correct. I am ignoring ‘gas (e.g. oxy-acetylene) welding, which is probably not worth considering for occasional DIY use. What I think is the situation is this:
1…What I would regard as ‘traditional arc welding’ is variously described as “stick welding”, “MMA”, “MMAW”, “SMAW” and various other things, all different names for the same thing. It involves an electrode/rod coated with flux which, when heated, gives off a vapour/gas which shields the weld from oxidation etc.
2…Then there came MIG welding. Initially, as the name implies, it involved the use of an inert gas from a bottle/cannister to shield the weld. However, we now hear a lot about ‘gasless’ MIG welding, and that seems to involve use of an electrode/rod which has flux in its core.
3…It therefore seems that the only difference between “stick” and ‘gasless MIG’ welding is that the flux exists as a coating in the former and as a core in the latter. Is that correct and, if so, what is the practical significance of this difference?
4…All of the above involve the use of a ‘consumable’ electrode/rod which melts and becomes the weld that becomes incorporated into the metals being welded – so seemingly in many senses analogous to soldering/brazing. TIG seems totally different, with a non-consumable electrode/rod -so I presume it works simply by melting the materials being welded – sort-of ‘fusing them together’, with no added matetrial (although I gather that material from a rod is often also added).
Is the above all roughly correct? If not, please put me right!
Thanks to all of you for your time (and patience!).
John
Stick welding is where you you have a rod of welding material covered in a flux that shields the weld whilst you weld the material.
MIG is where the welding material is a wire on a roll that has a flux core. The wire is fed out on a roller system contained in the welding machine. The flux core allows the weld to flow and the gas shields the weld although as you say MIG can be done gasless. The small gas containers that are sometimes supplied with the welding kit do not last very long.
TIG welding uses a seperate welding rod, pretty much like soldering, and an electric arc to melt the materials. I haven't tried TIG but I have tried MIG and stick and wasn't very good at either.
The you tube guy is called Proper Do It Yourself and he has tested some of these things including the waste of time ones.
Proper DIY actually
