I'm just running into a similar problem with a new build property, except my options to resolve it are limited.
Situation:
I'm buying a new-build property, I get to design the kitchen and specify the appliances. I've chosen a 90cm Neff induction hob with a total power requirement of 11.1kW. I chose it for the feature set, and to go with all the other appliances, esp. to be able to control the ceiling-mounted extractor hood.
The kitchen has had 6mm copper installed. The electrician used by the developer is saying he will not certify the installation if this hob is installed, "for safety reasons".
The hob has a "Power Limitation" feature which allows total power used by the hob to be limited.
My view is that the “Power Limitation” setting is not a safety feature, it is to prevent the appliance from pulling too much current and tripping the breaker, ie. it is to prevent inconvenience. The only bad thing that will happen if the power limitation feature is inadvertently disabled is that the breaker on the circuit will trip to protect the wiring, which is exactly what it’s designed to do. Also, bear in mind that this will only happen if the hob is operating at 86% of max capacity, ie. all 5 zones are operating at 86% of their maximum setting, which simply isn’t going to happen in any kind of normal use.
From what I've read in this thread, this hob should be fine on 6mm copper - is that correct?
Not sure how I'm going to resolve this.
