Random loss of TV signal
I've been getting issues with BBC1 and 2.
The picture will pixelate then sometimes recover, but more often than not will disappear completely and the screen will show Signal Loss.
But other non Beeb channels are tickety-boo.
The TV in question is the LG that used to be in our lounge, where it played the same trick.
Between this and the fact that the BBC1 app regularly shuts down and restarts because of a lack of memory, means I have fallen out of love with it big time!
Good point. I believe it is RG6 (copper coated steel core/'foam' insulation/aluminium foil & braided copper screen) but TLC don't provide a spec for this product.
Oh dear. Probably the worst choice possible. At least it's indoors and not being used for DC power to an amplifier. RF loss wise it's perfectly OK.
My gut says a boiler stops firing with a big splat (gas valve/oil burner pump) and then 20 s later the circulating 'over-run' pump cuts out with a smaller splat... Or something similar with failed / inadequate suppression. Perhaps a Saniflo macerator toilet only used at that time before bed?
It could be happening outwith your viewing hours too - but you just don't switch on and watch this TV earlier?
Would be better in a separate thread?
LCN 1 & 2 - SD? Watch 101 and 102 in HD instead. (HD mux also carries ITV1, C4 and C5 HD).
Prompted by that, I've just switched to 101, whilst we were on a BBC North program - It showed it in HD, when I've tried it before, it simply showed a banner, and no program content, until the national BBC came back on - so I've avoided using the HD channels generally.
Appreciate (now) that RG6 isn’t great but unfortunately it’s what is commonly available from even electrical wholesalers like TLC.
Your boiler start up scenario is exactly as I imagined but the fault occurs when the boiler is switched off, a.ong with all other internal sources of interference. I thought the suggestion of outside light sensors being triggered by animals (foxes and badgers in our case) was a likely one as well and switched that all off for a couple of nights to no avail. And no macerator!
Thanks all for comments about picture quality/ weak channels etc. The annoying thing is that outside the random blinks, the picture and sound are pin point perfect! As I would expect from the latest offering from Sony.
So the saga continues and my Sony TV is still blinking away randomly. I have had another TV/aerial 'specialist' in who plugs in his meter and pronounces no fault - which I knew anyway.
What I need is someone able to record signal input over time, demonstrate it and perhaps start to identify what is causing it. (A CB radio enthusiast has been suggested as a possible culprit?) Anyone aware of a genuine specialist capable of doing this in the Surrey area?
If it is only affecting the one TV, and it is a brief flicker, it's unlikely to be someone chatting on the radio - it would generally wipe the signal out for much longer. If you still think it might be, then see if you can get a CB/amateur radio filter fitted, in the coax - or even make one up yourself, they are not difficult to make.
Have you tried one of your other TVs in place of the Sony for the same time of night?
If it is affected the same way then that shows something in that room/outlet is the issue.
Even running two side by side via a 2-way splitter? To see if when the Sony glitches the other does anything?
Ditto with using the new Sony in another room/outlet at the same time to see if it performs equally as badly.
Ideally one would check the Sony at the same time period in a different dwelling some way away, too. Then one would know if the TV is faulty or the location (your home) has the issue.
Having re-read the whole thread to recall everything I am of the belief that this is a TV device fault rather than a reception or signal fault. So you have to either put up with it or try rejecting it with the supplying retailer as faulty (within 6 months of purchase the burden of proof it is/is not faulty will be on them).
Thanks Harry. I agree that its unlikely; just a suggestion. We are clutching at straws here!
I think I am going to have to do that. Unfortunately that the other digital TV is on a wall mount and the one in question is on a trolley - and both big and heavy. However, needs must.
I still think it is some kind of signal fault, it is too random to be device related. Or is it? I think I mentioned earlier that I tried to get info out of Sony's engineers what differences in the tuners there might be that would make the new one more sensitive but I just got a one-liner, "they're totally different".
