I turned off the cold feed to the header F&E tank, drain from ground floor drain valve for good 5 mins, went to the loft, water level in header tank down to third; pls see pic below.
You should give the F&E Cistern a thorough clean out before refilling the system. Also consider isolating the pump, remove the 4 stud bolts and pump head and clean out the impeller vanes with. a steel scriber or small screwdriver and a tie wrap, those Selectrics are outstanding pumps.
What you've done is unlikely to have made any difference to your original problem. Have you tried cleaning the pump impeller, as Johntheo5 and I suggested?
