Damp Patch and Slight Darkish Stain on Bedroom Wall
1 Dec 2025
I have a slight stain and some damp patches on a bedroom wall near the top of the wall. This has appeared in colder weather and is worse after rain. My roofer says there is no roof leak he can see, there is a capped flue with flashing for a gas fire inserted 3 years ago but this has no sign of water ingress. I’ve had gutters cleared as these were pretty blocked. There are 2 more unused flues and at least one has been filled with rubble , I can’t see the other one. There is one lower vent on one of the flues in the bedroom and I have just cleared a bucket of rubble from this and established an air flow by holding a candle to the opening. In rain today the wall is damper again . My questions are
1. Will if take some time before I see any improvement in damp now I’ve got an airflow in one flue where the damp was showing ?
2. Should I try and clear the rubble from the truncated chimney in the loft - could this cause any structural damage , should I get a builder to do this !
3. Would directing a heater fan at the vent help it dry the rubble if this is indeed the cause of the damp.
4. Should I strip wall of plaster and ‘smash’ it - a suggestion from a builder - what does this mean !
Any other advice appreciated
Put plastic over.
Water under the plastic its a damp wall.
Water on the plastic will show it's condensation.
Sounds like a cold spot and condensation to me.
Go watch skillbuilder YouTube channel which covers this. See if that helps you.
The answer maybe start dealing with the excess moisture in the air. We currently have two dehumidifiers running ever evening. Condensation on the windows is telling you there is a problem.
You could have cold bridging in the wall as well at that spot.
I am only guessing... it could be hygroscopic salts in the old chimney breast. Over time the old soot absorbs moisture during the summer months. Over winter, they leak the moisture in to the room.
Thanks for the reply, yes a lot of my research is pointing in that direction. I think I need to unblock the chimney of rubble as that may be causing moisture to permeate through the wall and bringing salts with it . Unblocking the chimney looks tricky !
If you shovel it out from the bottom, whatever is above will fall down.
Ventilation will evaporate damp, you don't need heat.
Do you think rain is getting into the chimney? Not much falls down the chimneypot, but sometimes there is a roof fault at the flashing making it damp.
Picture above wider , shows patches of damp on wall below rail , above it marked A feels damp . Below you can see air vent - I cleared bucket of rubble but think chimney still full of rubble. Not sure how to clear this ?
Wider pic please.
I think you mean the damp is over the flue, but I see no chimneybreast, so is the chimney projecting from the outside of the wall?
Is it wet with rain?
There are typically two flues in a chimney, one from the ground floor fireplace and one from the first floor. The ground floor one can wick up damp from the ground. Both need to be ventilated and rubble removed. Builders love hiding rubble in old chimneys. You might be able to look down them from below,
