Up to a point, but many of those expecting an extractor fan to cure their mould problems will end up disappointed.The simple choice is, either a slight bit of noise from a fan, or a bathroom filled with moisture and mould developing.
Probably more important is to try to avoid their being cold walls and ceiling when there is steam around (e.g. when having showers) - since once water vapour has condensed on those surfaces (there to promote mould), a fan will do almost nothing to remove it!
It obviously 'depends', but quite a lot of bathrooms and shower rooms, particularly small ones, are fairly poorly heated, not uncommonly only by a heated towel rail (or, sometimes, the dreaded underfloor heating!).Few will enjoy having a shower in a cold room, so it's a fair assumption the room will be reasonably warm - which just needs the use of a fan, to extract the moisture, before it eventually condenses out on the walls.
Whatever the theoretical discussions, I have certainly seen many cases in which an extractor fan, alone, has not cured a mould problem.
I wasn't suggesting a choice ('either/or'). Rather, I was suggesting that if one installs only a fan without also ensuring that the walls and ceiling are pretty warm when taking showers, one is quite likely to end up disappointed in relation to the effect on mould.... if the choice were between heat, or a fan, then I would choose the fan, as the more effective solution.
When I had CWI installed, the bathroom (on a corner) got much warmer and drier, with the same existing radiator and fan. I don't even get mist on the bathroom mirror now.Up to a point, but many of those expecting an extractor fan to cure their mould problems will end up disappointed.
That assumes the air change is fast enough and adequate fresh air entering otherwise warm surfaces play an important role.I was trying to point out, that the extraction of moist air, is more important than warmth in the fabric.
I'm not sure how either of us can be very sure about the relative importance of those two things. What we may be able to agree on is that it is better to address both than just one?I was trying to point out, that the extraction of moist air, is more important than warmth in the fabric.
What do you mean by 'warm moving water' - do you mean 'in pipework'?I can only look at this from my experience in the controls industry, in situations where warm moving water is likely the air temp is commonly set at a minimum of 2 degrees higher than the water temp.
As I said, I've certainly seen many examples of installation of a fan (alone) not doing much, if anything, to alleviate a mould problem - haven't you? I suppose that one doesn't need any more than eyes to assess the situation - if, after installing a fan, there is still condensation appearing on walls and/or ceiling, then I suspect that any mould problem is likely to persist.
Exposed water which gives rise to wet air such as bathing areas.What do you mean by 'warm moving water' - do you mean 'in pipework'?
