Is there any scope to run drainage along the Left Hand side of the Building?
My basin and shower waste connect directly into soil pipe adjacent the toilet , not an issue for BC.To Building Control e.g. connecting to main sewer for ground floor toilet
2.4m is quite wide, I don't see an issue with running a drain through there, provided the existing Foundations aren't undermined.
A lot of issues with some of those complex runs is the fact that (height position wise), the pipes could clash with each other.That all sounds eminently sensible and deserving of a deep dive - I had expected nothing less from you when I decided to post on the topic. All that and the resident particle physicist's had a bit of a laugh too. What's not to like
Thanks again.
Precision doesn't work like that in the ground. Plus there might be other objects in the ground that could influence the height of the pipes.The fall calculation and positioning of the various elements was actually undertaken exactly so as a clash never occurs (i.e. the whole thing "fits").
