Absolute safest way to wall mount TV on plasterboard
Looks like the bracket they give has a bit of depth to it, and I take it that ends up inside the wall
Cut a square of plasterboard that will be hidden behind the tv, out from between two adjacent studs
Cut a square of hardwood 18mm ply at least 3 times the height of the bracket and as wide as the gap between studs
Glue and screw battens to the edge of the ply face, on the sides that touch the studs
Mount the ply by screwing through the battens sideways into the studs, such that the ply is deep inside the wall and the perfect depth that the TV will be flush with the wall when on the bracket
Hang the TV hiding the hole in the wall. Use the internals of the wall as a service void for cables because nothing ruins a flush look faster that an hdmi lead snaking its way up from the DVR below to behind the TV
The bracket they supply folds up to fit within the back of the TV itself - It's really neat, though there isn't enough swivel for my uses. I've actually bought the same TV
Tet
Update:
Those Geefix fixings....I drilled my first hole and hit a batten, tried a second hole, metal stanchion. third hole - bingo! another batten
There is a small void between the plasterboard and the batten, so direct fix is out as the plasterboard will flex and I now have a 1" hole so a corefix fitting is out of the question
So I now have four 1" holes and need some way to fill them with some kind of spacer. I'm torn between widening the holes a tiny bit to 28mm and then using an old curtain pole as spacers, otherwise buying some nylon or aluminium 1" rod and cutting that down
Any other ideas?
Regards
Tet
Am I missing a trick?
If you're hitting things to fix to, can't you attach to those?
I have battens, but I have a void as well. If I fix my bracket with coach bolts for instance then I will be tightening the bracket and crushing the void. I'm looking for a spacer to directly compress the bracket onto. In theory I could do it with a dozen or so large washers, I'm thinking that a wooden or aluminium rod would be preferable
Am I incorrect about the bracket and the crush?
Regards
Tet
Impressive; in the OP's pic the bracket seems to be about 4 times longer than the TV is thick?! If it folds flat then same advice, just mount the ply at the appropriate distance so it's flush with the wall surface etc
Any other ideas?
Use a 1" hole saw (the same thing you used to make the hole??) to bore though a bit of wood the same depth as the hole, which will leave you with a 1" plug of wood with a hole in the middle i.e. a very fat wooden washer
Like the sleeve of a corefix fixing, only better at spreading the load from screwing your bracket on
