OK may be unusual as my flat under main house, not used that much, and used in the main by my daughter when she stops over, and she may well swap bulbs if one fails, so noted bulb failed and got new, about to drop old one in the bin, then thought is this simply a smart bulb turned off, in the main smart bulbs will if power switched off and on, auto switch on, but the one I had used in the flat was an odd one out,
it did not connect to internet or phone, but came with a remote control, as wanted a light which visitors could turn on/off when in bed. Should not have been in kitchen, but as said daughter could have swapped bulbs around.
I expected to look at the bulb, and simply read what it was, but seems this is not the case. I have had problems with G9 bulbs, the small one
complies with British rules, and gives wattage and lumen, but will not work with my smart switch, and is like a tocH candle, the big one works great, except covers will not fit, but does not have a single marking on the bulb, so only way to get them is from the internet, as lack of markings means they don't comply. But I like to support local shops, so where I can, I buy local, bad enough when wife uses these people who leave parcels all around the house, without me doing it too.
But if local bought bulbs don't tell you what they are, may as well use these delivery services.
