Central heating
11 Jan 2026
Hi . New to this . Just after some advice . First thing . What is this pump and what does it do . And what is the best number to have it on .
2nd my heat does not seem to turn down . Should the valves on the radiators be fully open ..thanks in advance mark
To help.
Do you have a wall thermostat?
What boiler do you have?
That's the heating pump to move water around. Plumbers here will advertise..
Do you have TRVs and lockshields valves on your radiators?
Re pump speed that all depends on how effective the pump in distributing the flows to all radiators and is particular to the system its serving, generally lower the better for a bit of energy saving but start on 1 and progress upwards depending if your radiators are getting warm enough.
Pump speed on those is often on 3. Heat does not turn down - do you have a room thermostat? Are the radiators too hot?
I have these ones . Do they need to be fully open . Thanks for your help mate
Don't need to touch them if the radiators are heating up. As above, start the pump on speed 1, it it all works leave it there, if not turn it up to 2 and try again.
I have this one . But it's near the front door . Probably the coldest part of the house . Is this why the radiators are so hot . Because this is cold .
The lockshield valve. Should I have this fully open mate . Sorry to be a pain . I'm a joiner and this is all new to me .
Cheers mate
Thanks for your time and help mate
Got a plumber coming out to look at it ...
Nice one mate
Do you have zone valves on your system? If so, the heating one could be sticking. Simple enough fix for your plumber.
