chucking what gunk is removed down the kitchen sink?
I'd be using the magnets to catch as much as possible and then dumping the water down the loo, not the sink.
Sounds like you need to find someone you can trust to properly diagnose and carry out the necessary repairs. That can be difficult.Any input much appreciated. I don't have great DIY skills, so I presume this is beyond my own abilities. Know Your Limits
Family recommendations, local social media groups and the like can help. Research the companies/installers if you are unsure, but you'll ultimately need to rely on someone to put things right.
Agreedwhich can be dealt with with chemical clean and hot and cold flushes in the vast majority of cases . But then again that doesnt generate £££ for unnecessary work
A skill worth learning. Paying an engineer to do it doesn’t make sense to me given the time it takes.Balancing can actually be done by anyone, although it requires a lot of patience.
I only concern myself with 2 and then ensuring the heat curve of the boiler is appropriate for our house.I see 2 different distinction with balancing when it comes to central heating systems -
1- Balancing rads to obtain the correct ΔT across the rad to ensure the radiator is delivering its documented output and can replace the heat loss for the space it's been sized for. Also to try and ensure that a condensing boiler condenses as much as possible, maximising efficiency.
2 - Balancing the system to ensure that all the radiators heat up at the same time to try and ensure all the spaces and the overall property heats up uniformly, maximising comfort in as fast a time as possible. That also aids in maximising efficiency.
IME, the whole process is really quite fickle to try getting the 'mid point' between the 2 just right.
One additional thing I did notice is that if I isolate one of the problematic rads
that still doesn’t get warm all over, is that the diff between flow and return temp is small. Whereas if I look at one of the “better” rads then the diff is much bigger.
“Claiming sludge in a customers radiator and quoting for powerflushing is the biggest racket going on in the heating industry (in fact powerflushing could do more harm than good).”
What exactly do you mean by “isolate” there?
What shape / style of radiators are they?
