- Joined
- 5 Nov 2024
- Messages
- 4,081
- Reaction score
- 2,069
- Country
Not sure if this helps? https://www.amazon.co.uk/Finder-133182304300PAS-Built-Switches-250-VAC1/dp/B00RBYS9BA
YEs that one is good - I could not read the details from the picture but you found it
A lot of programmers are only 3A, so why would a relay be needed? Heating systems are fuse rated with 3A too so I’m slightly confused.I can see from searching that this is a common issue with Tado receivers - only about a 6A contact so probably not enough.
It’s a Y plan, so should be Tado - MV - Pump and boiler switch live, so still confused as to why it would be the pump drawing too much loadIt is the Tado doing the switching
Well done, you found the one in the picture. The problem is I cannot install it any where near the receiver.
Read what hte TADO CS said, a pump can give a large load/high inrush current on switch on.A lot of programmers are only 3A, so why would a relay be needed? Heating systems are fuse rated with 3A too so I’m slightly confused.
perhaps using a solid state relay instead.
The pump is in the airing cupboard with the wiring centre.Where is the pump? You can install it next to the pump - in fact it is probable better there.
I did read it. What I also saw was a com to no on heating, not on dhw.Read what hte TADO CS said, a pump can give a large load/high inrush current on switch on.
It's a common problem according to Google.
Probably understand it better than me then. I’m only a gas engineer with limited heating wiring/electrical knowledgeI build electrical control panels for much much larger pump, we sometimes have to increase/swap the MCB for a bigger one/different type than what was expected.
