Is this article a Red Haddock ???
I have heard it said many times, an electric heater is 100% efficient, it does not matter if a fan heater, a panel heater, or an oil filled radiator they are all 100% efficient, but this is not true.
If one wants a room at 22°C at 6 pm, and it is at 16°C at 5 pm, then likely the fan heater needs to be switched on at 5:45 pm, the panel heater at 5:30 pm, and the oil filled radiator at 5:15 pm as it has to heat the heater first, so at 2 kW we are using 0.5 kWh, 1 kWh or 1.5 kWh to pre-heat the room,
Yes, but you continue to get the energy back, once the heaters are switched off.
Edison pushed for DC power — smooth, steady electricity that ran efficiently through devices.
Edison promoted DC as that is what he supposedly 'invented' and was therefore financially invested in having it used.
At the time, DC was very far from efficient, as it was next to impossible to convert to different voltages, with the result that voltage dropped significantly as you moved away from the generator.
Nothing electrical at the time required DC, and there were zero benefits from having DC. This is a time before any electronic devices existed, and the only real uses were for lighting and heating. Motors on DC did work, but they were far worse than the AC versions.
If Edison had his way, there would have been tiny little generators everywhere, hundreds in every town and city, just to keep the voltage at a usable level at the consumers. Massively expensive and inefficient, electricity would be for the chosen few only. Mass adoption would never happen.
There was zero innovation or research involved - it was just taking something which worked on a tiny scale and then hoodwinking the gullible into installing it into larger buildings and streets.
Edison later specialised in employing people to invent things and then taking all of the credit for those inventions. Biggest charlatan of his era.
Tesla promoted AC power — easier for power companies to transmit across long distances, but wasteful once it reached homes.
Tesla promoted AC because he had actually bothered to do the research and experimentation to find out how it worked.
At the time, AC was the only way to transport electricity over long distances, and therefore the only way in which entire cities could be connected to electricity supplies.
There was no real waste, as it was all lighting, heating and motors - the motors being mainly based on designs that Tesla had developed and would only be possible with AC.
For modern electronics which use DC, there is a small loss converting AC to DC. However this is tiny, and even if properties were connected to DC supplies the conversion would still be required, as whatever voltage was supplied to a building would not be what was required by the electronic device.
But once room not occupied, no gain. What we hope is the room never cools to ambient. Today phone tells me 6°C outside, my thermometer shows me 1768665787481.png 11.1°C unheated room with door open to heated room, 18.1°C my bedroom, 17.2°C the flat under main house, not heated, but boiler is there, 20.1°C the living room. Dining room at 14°C and hall radiator TRV 13°C the hall thermostat 17.5°C, so I would say likely with no heating on, for 12 hours, house around 10°C, so room used once a day, only likely 4°C higher than ambient. So no not getting the energy back.
The whole point was that ebee was promoting the 'truth' that DC was a better form of distribution, but that greedy industrialists wanted to do it cheaply using ac. As he didn't want distribution to cost anything either it lead to the conclusion that either distribution should be at 12V dc which would result in unacceptable waste, or that it should be at a higher dc voltage which would result in the need to transform this higher voltage on the premises. Which I was suggesting is impractical at that scale.
The article then went of into realms of fantasy involving 'cleanly flowing dc electricity', and being able to smooth it out with dummy capacitors filled with sand. As these stupid scam devices get raised here once every two months, I couldn't see the point in suggesting that there may be truth in these ridiculous statements.
Ebee said no such thing, all he did was quote the points put forward by Tesla and Edison, in regard to the comparative values of AC versus dc for distribution. Back then, AC was the only practical way, to transmit power any distance, but now, with modern devices, it is not quite so clear-cut...
Today, most devices in the home, rectify the AC, then SMPSU's translate the voltage to the required DC voltage. Even motors can be brushless, 3ph, fed from a DC supply. I cannot even think of a device in my home, which particularly demands AC to run. From memory, my first home, ran on 210v DC supply.
He never mentioned distribution at 12v dc!
Excellent run down of what is what there by Flameport. I find myself pretty much in agreement with what he has said.
Just to add,as with nearly all of the conspiracy theories and "Scam" or "Fake News" type advertising there is usually a nugget of truth in there somewhere.
Whether that nugget is one paragraph or one sentence or one word, it tends to be that which some readers latch onto then take everything else as gospel truth too.
Some poloticians have an amazing abillity to utilise this too, they hone their craft to near excellence. Start out with one truth (or almost truth) then then come up with a raft of things that, at best, can only be described as "A different version of any truth or downright fallacy" and hey ho. Not many of them would last long if they did actually tell the truth.
it`s up to us to try to form a reasonble opinion of truth or untruth or partial truth.
We have all seen the adverts
and we think, will it work? The heater, plugged into a socket I would never entertain, but the fan on the radiator, seemed an interesting idea. I had a proper Myson fan assisted radiator in my old house, and it worked well, so I had a thermostat to make beer with, and some fans for summer, so put an upright fan next to radiator and the thermostat on the radiator return pipe, so it would only run when return pipe hot.
I became apparent that the fan was far too big, but also would need some re-adjusting of lock shield valve etc. And I got the room hot by adding a TRV to hall radiator so the thermostat also in the hall powered the boiler for longer.
Main reason not to use the fan was noise. But the claims do go a bit silly, yes likely heat the room up faster, but it will not save money.
We have all seen the adverts View attachment 405149View attachment 405150 and we think, will it work? The heater, plugged into a socket I would never entertain, but the fan on the radiator, seemed an interesting idea. I had a proper Myson fan assisted radiator in my old house, and it worked well, so I had a thermostat to make beer with, and some fans for summer, so put an upright fan next to radiator and the thermostat on the radiator return pipe, so it would only run when return pipe hot.
Years ago an elderly friend had heating problems, the lounge, where thermostat was, was always cooler than wanted but the rest of the house was very hot, the heating ran for long periods. I tried turning the lock shied valves down and yes it made a difference in as much as other rooms were a little cooler but turning them down further meant the boiler over temp stat opened and took ages to reset.
However the real problem was the lounge radiator was obstructed by the sofa and the room was so small there wasn't many options available to resite either. I added some papst fans from 19" rack units to blow air into the limited space betwixt sofa and rad which made a difference.
Ultimately I cut a hole through the lathe and plaster wall and set the 4 fans in the wall between the bedroom and lounge rad's which backed onto each other such that bedroom rad hot air was being blown in behind the lounge rad. I wired it to the room stat with an additional stat behind the bedroom rad to make the fan run on until cooled but with a switch which they turned the fan off a while before going to bed to raise the bedroom temp. A lot of rebalancing later it worked very well and yes it did save money as the boiler cycled more often, preventing the other rooms overheating.
