Well, there was no filter before and I didn’t ask for one.
It is a requirement, rather than an option, and the warranty on your boiler, will probably not be valid, unless one has been fitted.
Depending on make of boiler and if you are on water meter it is advisable to have a small expansion vessel/ shock arrester.
Good practice would also be to install a scale reducer on the incoming main to protect the plate heat exchange
Yes, Glasgow is typically considered a hard water area.Only if a hard water area.
Can't be arsed to look up if it is... Scotland, no idea without looking.
Gas Safe guy didn’t mention it, the 2 British Gas services of the Baxi boiler didn’t mention it.
You need to find a better quality of installer/plumber.Over the phone they insisted that even if Flow / Return are now wrong way round it “makes absolutely no difference, I’ve been doing this for 20 years mate”
No, as with most of Scotland, it is soft.Yes, Glasgow is typically considered a hard water area.
As regards a filter, Harry wrote:
“It is a requirement, rather than an option”
Gas Safe guy didn’t mention it, the 2 British Gas services of the Baxi boiler didn’t mention it. One of the power-flush plumbers did say he’d add a filter after the flush was complete.
I would always want to powerflush the system if fitting a New boiler.Thanks for the answer.
2 different matters, though of course same property. The whole Gas Safe aspect was to do with the Baxi boiler installation ca: 2 years ago, which I included to give some context/background.
The sludge issue, or rather the "some radiators dont get very hot at all, very patchy at best" is the "now" issue.
With respect, you've been shown that it is mandatory. I agree that you don't know what you don't know, but you seem reluctant to accept the facts.I'm not sure that a filter is mandatory
Baxi say a filter "must" be fitted, in line with the regulations imposed in 2022.Nonetheless, point taken, I will check this with Baxi Support
