Am adding some sockets in the kitchen. There is already a single beside a redundant tv aerial point and plan is to link to this.
On investigation the cable to the socket is a spur taken directly from one of the ring circuits at the CU (about 10 feet away in the garage) and wasn’t put in by the builders as the sheath is grey rather than white.
Plan is to use existing cable from CU to an FCU and then on to two double sockets so everything downstream of the FCU is protected by a 13A fuse. There is a spare way on the CU but there is no fuse carrier and it is a 70s MEM unit with rewirable fuses.
Medium term (6months) we intend to get the CU changed and this would probably get its own breaker. Longer term (12-24 months) the kitchen will get redone ant it would be absorbed into the kitchen ring properly.
Now the FCU will be about 2 metres away from the CU so that run will only be protected by the 30A fuse - is this OK?
