NON CONSISTENT HOT WATER PLEASE HELP
9 Feb 2026
I have a Heatline Capriz 28 boiler. New Heat exchanger, new diverter valve, new outlet let pipe. Central Heating works fine, but the problem is with the hot water. When turning the tap on, the water temp is not consistent e.g. hot, warm, cold on loop. The flame indicator on the boiler switches between being on/off a tap is running. Plus the pressure dial seems to fluctuate when this happens. Again, it loops, flame icon comes and goes. I have attached a few pics. Please help. I've had professionals look at the boiler and the issue is baffling
Appreciate the help
Regards
Michael
Hi. Yes, all my taps are mixer. Including the shower. Its starting to become a little costly now having replaced a number of Components. .
Any ideas
Simple tests should have been carried out before replacing components. This rate it would have been cheaper having a new boiler.
Any ideas
Yes, are you able to isolate the cold feed into the boiler? If so, do this and run some hot outlets. If you get water trickling or decent flow you have let by of a mixer.
Thanks. I just tried this and no water came out of the hot tap. Managed to switch the cold feed back on.
Have you heard of any other situations like this?
A few. Often the diverter or motor, but you said this has been changed along with I’m guessing the plate heat exchanger, which would be the next idea. However, you mention the boiler isn’t seeing the hot water demand, so could be the flow sensor.
I did manage to find some info around the flow sensor being the issue, but wanted to get some forum feedback. Appreciate your feedback.
So could the flow sensor cause pressure gage fluctuations? When I run the tap the hit and cold fluctuations are coupled with the pressure gage running up and down between bar 1 and 2.
Do you think The pump can be ruled out? I purchased a refurbished pump with a top speed of (setting 3) pw 90, whereas my older one had a top speed of (setting 3) pw 75. Pictured.
Just had a thought. Is it worth changing the NTC temperature sensor??
Do you have any hot tap that isn't a mixer? If you open that tap, do you still get the cycling? If no, perhaps it's the classic fight between a thermostatic valve and a combo boiler that can't establish a steady state - the valve is open, the hot water starts flowing at eg 70 degrees, the valve gradually closes to shut it down as it strives to maintain 38 degrees by mixing etc, the flow slows through the heat exchanger leading the water to spend more time being heated by the flame, leading to a rise in temperature of the water, the boiler modulates down but can't go low enough so shuts off, the flow cools, the valve opens, the boiler resumes heating, lather rinse repeat
Is the cycling still observed with eg the shower head removed? Do all thermostatic mixers in the property do it when opened full bore?
Pressure fluctuation might suggest overheating situation
With that boiler and fault you are in boiler engineer territory plus that boiler is a little handful to work on.
You need someone who repairs boilers rather than fits them who knows how the appliance functions.
Chaps who have replied at least one I know knows what is wrong with the boiler
While the appliance is called a boiler, water should never reach boiling temperature. In your boiler I suspect that is happening hence the pressure indication fluctuations
