Wiring in a 1 gang 2 way Wifi switch no neutral
2 in each
L: Black with brown sheath to send power to the L terminal on switch 2, plus solid brown to send permanent power to switch 1.
L1: Brown with brown sheath - live coming from light. And a solid brown, again to send power to the L1 port on switch 2 as it won't power up without 12v to L and L1. Despite what the manual says, unless it's defective.
I now have 1 solid brown at switch 1 not connected to anything, and the grey sheathed brown isolated at each switch, not connected to anything.
So how many wires do I show in L?
I'm out
I've almost sorted it. To confirm
Master switch:
L = Perm live from consumer unit plus brown wire from 3 core linking switch 1 to switch 2 to provide a perm live to switch 2
L1 = Live from ceiling light, plus brown sheathed black strapper wire to provide 12v to L1 at switch 2 else it won't power on
One remaining brown wire which I assume is a loop out to kitchen. I suppose I'm supposed to shove that into the L terminal for a constant 12v supply though i'm not sure how safe that is.
Switch 2:
L = brown wire linked to 12v perm from L on switch 1
L1 = black wire sheathed brown from L1 on switch 1 to send signal and provide 12v to L1
Why do you suppose anything when I have repeatedly advised you to do it?
Is it?
How do you expect it to work without?
I posted that post just after you posted yours so I didn't see it.
And yes it is. The guide shows just a neutral and live going to L on the second switch, despite buying a 'no neutral' switch so I thought just having a permanent live to L would allow the switches to communicate to eachother via wifi
Anyway all buttoned back together after fitting the capacitor and working flawlessly via Smart Life and by voice command to Google Home.
Decent build quality, just hope they last so I don't have to go in there again. Master needed a 10mm spacer, other switch everything fit in the 35mm backbox.
Thanks all and apologies for the frustration. The more annoyed I got with it, the more logic flew out the window. Safe to say I'll never be an electrician. Think I'll leave it a while before tackling the 2 gang 2 way switches for the landing. Once those are done the rest should be much easier being 1 way throughout.
For when I've just walked through the front door and don't have my phone on me, or simply so I don't have to take it out of my pocket and ask it
I thought like me, you were using Google Nest Mini's, so I need to turn on lights with phone while sitting in the car, but once I walk through the door, I just add "hey google" in front of the command, and it does it. Hey google turn kitchen lights red, and it will do just that, or turn kitchen lights to 50%, and it will dim them, each bulb has its own name, so hey google turn on sink, just turns on bulb aimed at the sink.
It was not really by design, we have no FM radio reception in the village, so all the old FM radios simply don't work, so got Nest Mini speakers to replace the radios, then found they can do other things as well, living room lights have a smart switch, as chandelier takes 8 bulbs, so there is a mixture of smart bulbs, relays and switches.
Problem is wife has got use to voice commands, like hey Eric make me coffee.
