Ridge tile - Old mortar won't budge
29 Jan 2017
Hi guys,
Ridge tile got blown off by one of our many winter storms. Mortar below is very solid and I'm unable to remove it even after a fair bit of persuasion with hammer and chisel. I think if I apply more force I'll end up breaking the first row of roof tiles and I'll be up sh*t creek even further.
Any tips? Can I score, re-bed with sand+cement and SBR mixed in for better bond? There's about 10cm in the middle that is deep enough for new mortar bedding but the ends are very solid.
Hi guys,
Bin the tiles and put new ones on.
All things considered replacing the first course of tiles seems the easiest solution. Need to go get actually get some first. Thanks all!
Genuinely, a grinder with one of these fitted:
will make mincemeat of stuck on mortar lumps in seconds. Also a diamond cutting wheel will quickly clean up the ridge tile without risking breaking it. Dont use a hammer for any of this cleanup
On the grinder note, buy a battery one; all round better than a 240v one for most jobs (less aggressive), and will possibly end up being one of your most useful purchases. If you already have a cordless drill (if not why not) buying a body from the same brand so you can use your existing battery is usually incredibly cheap.
If you have a cordless drill and don't wish to lay out on a grinder, for this task you could consider an adapter boss that will allow you fit a grinding wheel to the drill(like eBay item number 317562734958) but take care to use a low speed, both hands and only grind such that it's trying to pull away from you if it suddenly grabs and jumps.
Specialist drill bits also exist, such as:
But for the cost of them you can nearly buy an angle grinder body, and I personally feel that for this job a grinder would be safest all round
New row of tiles is going to look very odd for years til it weathers in, go with what you have
All that whilst balancing on a ridge. Joy.
Ha I'd have loved an excuse to get more tools and would have if it was a few lumps but it's the bed along pretty much the entire length of the two ridge tiles that's not budging.
I've located some reclaimed tiles of the same type online, so will take the top tiles and bed off and replace, re-bed on identical tiles.
Anything to be aware of going down that route?
Angle grinders can be used single handed, leaving the other hand free to assist your balance if you're not confident in it.
Much better than swinging a hammer and chisel and breaking more than intended
I'm surprised though; you sure post a lot of roofing pics for someone who intimates they worry about being up there?!
I don't understand. If you are not succeeding in your attempts to remove some tiles because they're well cemented on, why are you attempting to remove them at all? Use a grinder to clean up the one that came off, and the area in which it sits, then re-bed it?
Show a picture of the problem?
Robin! You can't seriously be giving advice to a novice about using a grinder on a roof one-handed, especially with that attachment you have recommended. OP if the old cement is still solid, and the replacement fits well, then stick it on with expanding foam.
Always a toss up with these things, but the OP seems competent enough to climb on a roof and use a hammer and chisel to remove ridge tiles, so I assume that they would practice with a new tool on the ground first while maintaining a sense of responsibility to themselves not to operate outside their comfort zone.
All in, all the battery grinders I have are much more docile and controllable than the 240v ones, to the extent that I wouldn’t even think of picking up an AC grinder any more..
When I did ridge tiles I sat on it , straddling an old blanket , no balancing required .
Apart from the bucket, the ridge tile, any roof tiles, the hand tools the power tools. :sneaky:
The trick is to have only what you need when you need it and to take up as little as possible. We go up with a brick hammer in an empty bucket and a bolster chisel in one pocket and plugging chisel in the other. We remove say two ridge tiles. Pass one behind you and sit it on the ridge. Pass the other to the compo mixer. You clean the gear off the roof and put it in the bucket. He comes back up with the ridge inverted and full of gear. You lay that end ridge and point it and shuffle backward and pass him the ridge behind to fill with gear whilst you remove another ridge and fill the remaining space in the bucket with old mortar.
And so on.
Taking all manner of power tools up there becomes a chore.
