Longer TV power supply cable
13 Feb 2006
Tyne and Wear
I have just fitted a new TV to the wall, but sadly the power lead is too short.
I am not sure the name of the TV end, but it's like the image attached.
I have temporarily used a normal extension cable, but it seems longer cables are available online for not much money.
Do all cables with this fitting fit any TV
not all tv’s have this fitting some are hard wired .
I just cut the plug off mine and extended it with two core flex.
Yes. There is no kind of voltage adapter/power supply in that cable, all it does is supply 240v straight from the wall socket to the TV, and the TV has a power supply built into it. Any lead you can find with the two ends pictured will power the TV
