Anyone measured how much gas or oil used to heat DHW with the central heating?
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
I can measure how much electric is used, built into the immersion heater controller, last two home, no option but use gas, one had a combi-boiler the other an independent boiler for DHW (Main 7) but I never took a note. In both cases the meter was not in an easy-to-read location.
I note with the electric, the day reading changes a lot, even the week seems to vary, I would assume the immersion thermostat has a large droop, so it's down to if just about to switch on, or just switched off. 28 days summer around 35 kWh, and winter 7.5 kWh can't stop oil heating it.
Why are you so obsessed with the cost of energy
I think I am annoyed at being conned for years. I was told so many times it was cheaper to use gas, and I never questioned it. The same when I moved here, was told cheaper to use oil, and again never questioned it. It was not until I had solar panels fitted, and as a result had an off-peak supply, that I even considered heating water with electric, and found it was very much cheaper to oil, clearly if not using solar or off-peak the difference would not be as much, but it seems I have been conned for years.
The cost is mainly due to heating pipes and boilers, before the hot water ever arrives at the tap. And it would depend on how much and how often DHW is used, as to how much it costs. If either the pipes and boiler has not fully cooled before next use, or if we are using a lot of water each time tap is turned on, the percentage loss to water used will decrease. And in the early days my dishwasher and washing machine were hot fill, and we were a family of five, so someone would be washing there hands most of the day, so pipe work never cooled.
Today I wash my hands maybe 6 times a day, so with my wife 12 times a day (going to loo) needing around a litre a time, but running off 4 litres to get the 1 litre of hot water. So looking at an under sink water heater instead. Mother house the gas boiler was next to the sink, but still not instant hot water, it took so long to heat the boiler, still running 4 litres of water to get one warm litre to wash hands.
There are so many variables, to sit back and say gas is x-p/kWh and electric y-p/kWh does not work, Distance boiler or cylinder to taps which have a huge effect, and also distance boiler to cylinder. My boiler (oil) would run for 20 minutes once a day, but old homes the boiler was turning on/off maybe 20 times a day for 3 minutes a time, even when tap very close to the boiler, for taps further away may run 5 minutes. So only real way, is to in summer when no central heating being used, to see how much gas burnt in a day, week, lunar month etc.
Since old homes the gas boiler also used for the shower, there is no way I could have measured how much gas water heating cost compared with electric. So I am asking the question, can anyone actually give some real figures?
How long do you think pay back would be for buying and having an undersink heater
I remember over sink instant (I think) gas fired water heaters where the gas fired up as soon as you opened the hot "tap"?.
I remember them in Uncles house, it seemed to work well. But I sure it boiled the water? I personally think a tap which can deliver boiling water needs to be independent of a tap which produces water you can put your hands under. It is an accident waiting to happen.
Next to sink I have two kettles, one will deliver a cup full of water at a time, the other boils what ever is put in it, more convenient when making multi-cups of coffee. In the past we have had many units to make coffee/tea, I would call them fads, from the coffee percolator, to double tea pot (bought in Turkey) or the glass flasks on hot plates to keep the coffee hot.
In my childhood we had an Aga cooker, with a kettle always on the boil, and the side boiler kept the DHW hot, and I suppose today having hot and cold taps or mixer taps, is a kickback from the days when DHW cost nothing, it was a byproduct of the cooking fire.
There is no reason why one should not pour a cup of boiling water into the washing bowl, and add cold to get temperature required. And likely only reason we don't do this is habit.
If you don't want to wait for your water, you could always fit a DHW circulator but after paying for it and the attendant fitting costs, you still won't be able to quantify the cost.
Look for the positives. Whilst waiting you will have plenty of time to think about another pointless post on the forum.
