10mm is the supply into a small ‘sub’ CU that controls the kitchen/extension When the kitchen gets done I’m interested in having two double ovens and maybe an induction hob.
It’s currently gas so there’ll need to be a cable out and I read anything over 15kW should be 10mm. Probably only Christmas Day when they all might be on full blast.
Now please use a pair of pliers to squash the strands down into a line (touching) like ooooooo when viewed end-on, and put a ruler next to it then post a pic; let’s put some science at it
