My setup is like this. I used a manrose coupler and duct tape on the joint but recently noticed that this leaks...
Th grey pipe is a manrose round duct.
Should I use one of those rubber boots with jubilee clip here?
Yes, a rubber coupling should do the trick. You need a soft material to make the seal.
Or better still, get a longer section of pipe so that there are no joints.
That's the longest I could get these 100mm manrose pipes in. Are longer lengths available?
Also, what rubber couplers do you recommend for these 100mm pipes?
