I have a basin to swap is cracked. About 10 years old. Imagine if he best of getting a new waste for the basin. What about the tap? If I keep the tap when swapping over would you replace the Flexi tails? Would be M10 ones monoblock mixer. Thanks
Thanks if removal tails, worth while replacing?If you want to avoid any swearing with damaged seals, just get a new waste, they're cheap.
If the tap is ok you can refit it.
Bear in mind that some taps don't have removable tails, so check that first.
Thanks it's a mushroom one that's inIf getting a new waste and going for a click clack... Get one of the mushroom ones as the whole thing can be pulled out and cleaned when needed... The internal throat ones get stuck and can't be pushed to pop up. You get call backs with these cos they is shyte!
Like this one...
RAK Ceramics Click Clack Deluxe Easy Clean Slotted Basin Waste - Chrome - RAKCCW003
Contemporary Style Easy to use and clean Smooth Operation with Quality Componentswww.tradingdepot.co.uk
Imagine it's an expensive tap though sottini ideal
It depends from their condition.Thanks if removal tails, worth while replacing?
If they're rusted, kinked, twisted or leaking, surely change them.
If they're fine you can reuse them.
Reusing them or swapping for new one?Biggest cause of house floods.
Not much you can do about it.No... Them failing.
