Is that a "widow maker" you're illustrating?
For years, yes, that is what we said, seen generators plugged in like that is Turkey many times, does not seem to kill them, maybe because they do it so much and Darwin's theory has got rid of the ones who have not learnt?
However, as the demo showed in this case the plug is isolated so fast when unplugged there seems to be no danger.
Yes we have discussed this system before.
They tend to call them balcony solar system in mainland europe.
Yes, I have my solar on a South-East roof, the balcony faces South, so in winter one solar panels hung from the balcony better catch the lower sun, and second is having a battery in the living room would power all stuff used in the living room during a power failure, the sockets direct on the battery, not back feeding into the house, and it is portable so also can be used else where.
Would not need them stacked up like this
but a portable battery pack which can be used with many different ideas in mind, is maybe better an addition than a fixed unit which only supplies 4 fixed socket outlets and the CH.
I have not delved into them, to look as setting them to auto charge with off-peak and discharge during the day, as yet just an idea, hence why I posted on here, I have been considering an extra battery, at the moment 6.4 kWh and only in March have I been seeing this last the day until next off-peak starts, so for 4 months of the year, my battery is not big enough. May 2025 to date electric has cost £188.40 this bill will go up, as the feed in has dropped from 15p to 12p, but all in all the bill is not really so bad at under £20 per month average. So not worth doing anything to the fixed installation.
But for the portable option with the balcony solar panels and battery, may tip the balance.
