- Joined
- 27 Jan 2008
- Messages
- 29,792
- Reaction score
- 3,694
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
With solar and battery around £200 pa, so saving around £1100 pa, I can say that as I also use around the same amount of power per day and have 6 kW of solar, a 5 kW inverter and a 6.4 kWh battery, the cost of electric is 8.5p, off-peak, 32p peak, was 15p now 12p export. So my gains will reduce but not that much. But @JohnW2 is correct, I was also looking at maintaining the boiler during a power cut, so there are other factors.total use 14kwh a day @ 27p = £3.78 per day with no investment.(£1397pa)
So which is the better option, a third 3.2 kWh battery on the existing solar, or a 2 kWh battery independent which can also be used for a picnic for example?
I could add more panels to roof, or add panels to balcony, so it is better angled for winter sunlight, and will grab the morning sun better. And no installation cost either scaffold or electricians.
To have electric costs around £252 per year, even if you use zero kWh, just the standing charge. To go off grid is not really an option, so as it stands, I over the last 10 months have paid less than the standing charge. But this is not the question, the question is should all be allowed to export power into the grid, using a DIY set-up.
