Door hinge screws not secure, quick fix?
15 Jan 2025
I've just remounted a door that i had taken off the frame for sanding and repainting.
Unfortunately, the door won't close now, it took me a bit to understand why:
Two of the screws on the lower hinge aren't holding, it seems their holes have widened too much with too many remountings. When the door is closing those two pull free a few mm and the door leans, not good
it seems like the best idea would be to use wood filler and then drill new holes, but this means i will have to take the door off again, do that, sand it, and repaint it, a couple more hours work at least.
I could use thicker screws, but i don't have any
I have a very busy week ahead and not much more time to spend on this problem.
Can anyone recommend a quick and dirty solution that might take care of it?
Shove some bits of cocktail stick or matchstick in the holes, then use the original screws.
hmm, thats not a bad idea, if only i had some
I have until tomorrow night to get this sorted, and its just enough time to buy this and get it delivered
Would this do the job? It could certainly fit in the hole, i have a caulk gun
but i normally use High Performance wood filler which comes in two parts you manually mix. Is this stuff going to have enough strength to retain screws?
As has been said but I prefer bamboo bbq skewers cut down to about 2 inch and you can hammer them in after coating with wood glue. I can also recommend hingetite screws
i just spent 25 minutes attempting to stuff scraps of newspaper into the hole, no discernible effect :(
So you got no matchstick - bamboo skewer or cocktail stick ---- clearly you dont host many BBQs
It's a really easy problem to fix.
You need any old piece of softwood - dowel, floorboards, joist cut off, garden fence as suggested above, etc etc - anything.
With a stanley knife, whittle the end into roughly the shape and size of the screw body, (but slightly larger).
Hammer it into the hole.
Cut it off flush (ideally with a chisel, but a stanley will do)
Drill a hole in the centre that is smaller than the screw size (maybe a 3 mm drill size).
Screw the door back on.
