Mobile Texecom Keypad App No Notifications
hi again, ive checked the settings (encryption keys) in the app against whats held in the panel and it all matches with com1 set to "1" in Encrypted Ports under UDL/Digi Options, Setup Modules. In Wintex, under Comms, Radio-pad and Com Port Options, there is an Encryption checkbox, which is also ticked. Wintex has the same 32bit key against the user account which ive updated. The app didnt have a key initially until i clicked on generate and the issues started from there. but assume its more secure now but just the notifications/alerts have stopped after this.
engineers code, 7 yes, (should say reset digi) yes
If that doesn’t work
Go to comport setup, com port the com io is on, press 0 press reset
Did that work?
Did that work?
Hi, I tried the reset, and no change
I did the reset on comport, added it back on, and still get the same error message under the notifications…
You will need to contact Texecom then, very little else Without having a play and not convinced I will get anywhere.
